ilaps Posted August 31, 2006 Posted August 31, 2006 I use DVBViewer.ge since a few months, and I-m fully satisfied. But for H264 channels, I'm changing my configuration which was not powerful enough. I reinstalled DVBViewer on the new configuration, but surprisingly, it works only 1 or 2 minutes, and then ask for username/password, with a message "after clicking OK, DVBViewer will be closed and must be restarted". And it stops. This behaviour is both for the version I had, than for the new version GE 2.0.2, loaded on this site what is happening? Quote
Guest Lars_MQ Posted August 31, 2006 Posted August 31, 2006 Make sure your username and password are correctly entered. Quote
ilaps Posted September 2, 2006 Author Posted September 2, 2006 Make sure your username and password are correctly entered. OUPS!!! you are right: i had confused the pw to go on the forum and download with the pw for soft install ! Quote
