Starting DVBViewer using the MCE remote
videomate
Is there a way to start DVBViewer using the MCE remote? When DVBViewer is up and running the remote works just fine but it would be nice if there was some way to launch DVBViewer using the remote.
/Henrik
So I guess you are already using Girder.
Then download my .GML file from this thread:
http://www.DVBViewer.com/forum/index.php?s...amp;#entry70555
There is also information on how to get the whole thing to work with Girder, but unfortunately in german.
Actually I am not using Girder, just the MCE plugin. But to be able to start DVBViewer I need Girder?
/Henrik
  • 6 months later...
/Henrik
How have you installed mce remote? I'm not be able to get mce remote working with DVBViewer. Only works the number keys.
I have installed the mce2005.dll as imput and the mce.remote as remotes but as I've said didn't work.
Thks.
Thks.
I like the HIP solution
http://byremote.com.au/HIP/
And you need this in plugin folder
Edited by Tottes
