ice coffee Posted September 4, 2006 Posted September 4, 2006 Hi, I have a TTs3200 and I have been playing around (installing/uninstalling) trying to get HD chans, which I now get but for some reason I have lost my CAM. It works fine in TT media center decrypting NDS video guard. but not in DVBViewer Pro 3.5 (or beta version) the show CAM button is just grey. I have definately enabled CI in the options menu !! If anybody has any info please let me know support.zip Quote
ice coffee Posted September 4, 2006 Author Posted September 4, 2006 I really am at my wits end on this one !!! I have completely uninstalled DVBViewer TT media center used the driver cleaner that came on the CD and then uninstalled drivers and yet upon re-install no CAM in DVBViewer !!! Quote
ice coffee Posted September 4, 2006 Author Posted September 4, 2006 still no luck, I have had another go at uninstalling everything, this time the first time it was started the CAM started working but the next time it was started it did not work !!! Quote
ice coffee Posted September 4, 2006 Author Posted September 4, 2006 Still no luck guys, any help much appreciated OK I have used the mantis CI detection tool (not really for my card but it seems to work !!!) here are the results C:\Program Files\DVBViewer>mantis function IsTwinhan("TechnoTrend BDA/DVB-S Tuner DVB-S") { GetPropertySet = SUCCEEDED. function BDAIOControl { PropertySet.Set_( CmdGUID = {255E0082-2017-4B03-90F8-856A62CB3D67}, dwIoControlCode = AA0001E4, lpInBuffer = 0012FD08, nInBufferSize = 00000000, lpOutBuffer = 0012FD20, nOutBufferSize = 00000000, lpBytesReturned = 0012FD18 to Tuner = {E5644CC4-17A1-4EED-BD90-74FDA1D65423}); Result = 80070492 } THBDA_IOCTL_CHECK_INTERFACE = 0 } C:\Program Files\DVBViewer> Quote
hdv Posted September 4, 2006 Posted September 4, 2006 Hello, please test this ttAPI.dll http://www.DVBViewer.com/forum/index.php?s...st&p=105779 Quote
ice coffee Posted September 4, 2006 Author Posted September 4, 2006 BiG thanks man it worked first time I dont understand why it worked at first and then stopped I dont understand why the thread you pointed me to is not in the Bug section since it is clearly a bug and lastly I dont understand why all my use of the search facility did not show up that thread !! Quote
