ilaps Posted September 6, 2006 Posted September 6, 2006 I use DVBViewer with an Intel D805 configuration. I use the Powerdvd7 codecs. I don't use DXVA on my CG, because it crashes very often on some programs (but it works perfectly with others. When I watch H264 HDTV, one core is used 90/100% and the other is 0/10%. And images are not really smooth When I watch the same films with Mplayerclassic, and the same codecs, I get about 60% on each core, and the film is perfectly smooth Does it mean that DVBViewer is not suited to dual core CPU? Quote
hdv Posted September 6, 2006 Posted September 6, 2006 Hello, have you set the option "Use only first CPU" off, to find in Settings -> Options -> General Quote
ilaps Posted September 7, 2006 Author Posted September 7, 2006 Fine , it works now! I hadn't seen this option! TYou Quote
