Question for Twinhan users
Exel
Do all of the keys of the remote control that comes with the Twinhan PCI DVB cards work with DVBViewer Pro and are all the keys genuinely unique (ie. no duplicate commands)?
I'm in the process of buying a second DVB-C PCI card and with it I definitely want to replace the sucky remote that came with my current Technisat card.
Thank you!
You can use both WinLirc and Girder with the DVBViewer so you can freely assign functions to a remote.
Assuming the remote supports them. The Technisat remote uses a USB HID device that is not detected by WinLirc. The remote itself has plenty of duplicate keys and some keys are defunctional by default. Some keys only work in the DVBViewer TE. That's why I'm asking if the Twinhan remote has full compatibility with DVBViewer Pro and if all of its keys are functional and unique.
