DVBViewer for Topfield recordings?
jouko999
At first thanks for excellent software!
The last version has stopped almost eternal whining about subtitles here in Finland.
I have also a Topfield 5100 box for cable and it records in normal ts format but adds its own
header to files and names them to .rec .
DVBV shows the recordings perfectly when the .rec files are renamed to .ts.
Adding .rec to DVBV:s supported files list does not make them work directly.
Topfield is not able to show files with .ts -extension.
There is a free FTP server for Topfield (via a USB-connected PC) and DVBViewer could be
easily used for watching recordings over LAN or WLAN without at first copying the files to
PC's hard disk.
I suggest you add support to .rec files to next version, and start selling it to Topfield users as a
remote watching software. The price is no problem because many Topfield applications are in same
price range.
