antdude Posted September 11, 2006 Posted September 11, 2006 Hello! I can adjust brightness, saturation, contrast, and hue settings just fine. However, if I go fullscreen/windowed mode, I lose them. However, my settings still has it. If I move one of the sliders, then it will be back to what it should be. Is this a known bug? Or am I the only one with this problem? Thank you in advance. Quote
Engelbert Posted September 11, 2006 Posted September 11, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
antdude Posted September 11, 2006 Author Posted September 11, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Attached my support.zip file. Quote
Engelbert Posted September 11, 2006 Posted September 11, 2006 Sorry. The support.zip, made with the SupportTool, not SupportTool.exe Quote
antdude Posted September 11, 2006 Author Posted September 11, 2006 Sorry. The support.zip, made with the SupportTool, not SupportTool.exeDOH! Sorry about that. It's 2 AM over here and I need to sleep. Reattached. Quote
Engelbert Posted September 11, 2006 Posted September 11, 2006 SMorning is also a day. Good night. Problem at SONIC decoders. SONIC audio decoder is missing.. Install newly! Not leaving on <auto> but adjusting tightly under DirectX video and audio decoder. At present this one recommends himself for PowerDVD 6 or 7 as a video decoder of Cyberlink (Trial suffices), as an Audi decoder of the Ac3Filter: http://www.free-codecs.com/download/AC3_Filter.htm Quote
antdude Posted September 11, 2006 Author Posted September 11, 2006 (edited) SMorning is also a day. Good night. Problem at SONIC decoders. SONIC audio decoder is missing.. Install newly! Not leaving on <auto> but adjusting tightly under DirectX video and audio decoder. At present this one recommends himself for PowerDVD 6 or 7 as a video decoder of Cyberlink (Trial suffices), as an Audi decoder of the Ac3Filter: http://www.free-codecs.com/download/AC3_Filter.htm Actually, I removed Sonic audio decoder because it only did stereo. And TE version didn't want to use AC3Filter. I have v1.09a from the latest K-Lite Codec Pack (Full; non-beta). I changed to PowerDVD v5.0 (don't have 6/7), and it seems to work. Are there any know problems with v5? I will have to play with DVD Viewer some more though. Time for bed. Edited September 11, 2006 by antdude Quote
antdude Posted September 11, 2006 Author Posted September 11, 2006 PowerDVD 5 is too old.Dang, what type of problems will I run into? Does using v7 trial expire in DVBViewer? Quote
Engelbert Posted September 11, 2006 Posted September 11, 2006 Only if the Trial is deleted by you without saving the decoders before. Quote
antdude Posted September 11, 2006 Author Posted September 11, 2006 Only if the Trial is deleted by you without saving the decoders before.OK, I will try that later. Thanks!! Quote
antdude Posted September 12, 2006 Author Posted September 12, 2006 At present this one recommends himself for PowerDVD 6 or 7 as a video decoder of Cyberlink (Trial suffices)OK, I haev v7 Deluxe installed. Um, which decoder do I use? Cyberlink Video/SP Decoder (PDVD7) Cyberlink Video/SP Decoder Do I assume the PDVD7? Quote
antdude Posted September 12, 2006 Author Posted September 12, 2006 OK! PDVD7.Thanks. Are there any advantages of v7 over v5 that I couldn't do before? Quote
Engelbert Posted September 12, 2006 Posted September 12, 2006 PDVD 6 and 7 is preliminary stages to high-density ability. Quote
antdude Posted September 12, 2006 Author Posted September 12, 2006 PDVD 6 and 7 is preliminary stages to high-density ability.Is that HDTV you're referring to? Quote
antdude Posted September 18, 2006 Author Posted September 18, 2006 OK, another glitch related to this. I was using timeshift. I had my brightness set up. Fullscreen to windowed mode and reverse was fine. However, rewinding or fast forwarding resets my brightness back to default. However, the settings show them at custom setting. Is this another bug or something else? Quote
antdude Posted October 3, 2006 Author Posted October 3, 2006 OK, another glitch related to this. I was using timeshift. I had my brightness set up. Fullscreen to windowed mode and reverse was fine. However, rewinding or fast forwarding resets my brightness back to default. However, the settings show them at custom setting. Is this another bug or something else?So, any suggestions on this? Any fixes? Beta fixed it? Quote
