Closing DVBViewer closes DVBServer
jouko999
When I run DVBViewer and -server in same machine all goes well but when trying to close the viewer it closes the server instead and stays running in background.
Seems the shutdown command kills the wrong process.
  • 2 years later...
Try deactivate the scheduler in the DVBViewer.
Hi.
I'm having this issue with version 4.2.1 and the suggested workaround works. Is there any way to be able to use the scheduler and the server in the same computer?
Thanks.
Kind regards,
mprost
TV card: Hauppauge WinTV MiniStick drivers 4.1.31.26239
Mainboard: Gigabyte EP45-DS3P
Graphics card: nVidia GTX 260, ForceWare 190.38
Edited by mprost
