Derrick Posted September 13, 2006 Posted September 13, 2006 16E, 11164H, 26000, 7/8 Program Number: 10 BTTES29/HD/A Descriptor: Maximum Bitrate Descriptor Maximum bitrate: 5241350 bytes per second Descriptor: Smoothing Buffer Descriptor SB Leak Rate: 625 SB Size: 1024 Descriptor: System Clock Descriptor External Clock Reference: 0 Clock Accuracy Integer: 2 Exponent: 1 Stream Type: 0x02 MPEG-2 Video PID 512 (0x0200) MPEG Video: Bitrate 38.963 Mbps Resolution 1920 x 1080i MPEG Video: Framerate 25 fps Aspect Ratio 16:9 Chroma Format 4:2:2 Descriptor: Data Stream Alignment Descriptor Alignment type: video access unit Stream Type: 0x04 MPEG-2 Audio PID 256 (0x0100) MPEG1 Audio: Bitrate 352 Kbps Sample Rate 48 KHz MPEG1 Audio: Layer I Mode Stereo Descriptor: ISO639 Language Descriptor Language: eng Audio type: undefined Stream Type: 0x04 MPEG-2 Audio PID 257 (0x0101) MPEG1 Audio: Bitrate 384 Kbps Sample Rate 48 KHz MPEG1 Audio: Layer II Mode Stereo Descriptor: ISO639 Language Descriptor Language: fre Audio type: undefined Quote
