Starman Posted September 19, 2006 Posted September 19, 2006 (edited) I have got Multicast working correctly. But I would prefer to use Unicast (as with Multicast it floods my wifi network rendering it unusable). So if anyone has experance of getting Unicast setup and working I would be most grateful for the advise. It should be noted that I have tried checking the manual (I have found it to be out of date and no help at all) and I have also tried seaching with no luck. Current settings. Edited September 19, 2006 by Starman Quote
nigelbb Posted September 20, 2006 Posted September 20, 2006 Mine is a different problem in that I use DVBServer & can only get Unicast streaming working not Multicast. Is there some advantage to using the NetStream plugin versus using DVBServer? Cheers Nigel Quote
Guest Lars_MQ Posted September 20, 2006 Posted September 20, 2006 Sometimes the router/switch can't handle multicast. Quote
