libor Posted September 21, 2006 Posted September 21, 2006 Hi, I have been unable to fast forward and/or rewind any media using the Girder plugin. DVBViewer seems to simply ignore the command sent out by the Girder plugin, although Gider receives the correct code from the remote control, triggers the associated event and the properties are set to send the appropriate numeric code (=the ones setup in the DVBViewer plugin for Girder DVBViewer.ini file) via COM. Anybody has an idea as to what this can be due to? I have noticed that the Rewind and Forward numeric codes are missing from the COM SDK .chm file although they are listed in the DVBViewer.ini file that comes along with the DVDViewer plugin for Girder... I am not sure what this means - are these commands unsupported by the COM interface or is it just a simple omission in the SDK docs? Thanks in advance for any tips/solutions! Cheers, Libor Quote
