Kungen Posted September 21, 2006 Posted September 21, 2006 Hi, I have recorded some programs with DVBViewer in .mpg format. Now I want to transfer those .mpg's to DVD. I've read through some very complicated instructions of how to demux, cut, mux, author etc... I don't want to do any of that: I don't need to cut out anything, I don't need DVD menus etc. Surely there must be a simple way to just transfer the .mpg to DVD+R without going through the above hassle? The resolution of the captured .mpg is the same as normal DVD, so no problem there either. Any help? Quote
Derrick Posted September 21, 2006 Posted September 21, 2006 If you want a "real" dvd according to the specs, you'll have to demux and author your mpeg recordings. You could also burn the mpeg files directly as data on a dvd-r(w). Many standalones can play raw mpeg without problems. Quote
