veracious Posted September 24, 2006 Posted September 24, 2006 Does DVBViewer pro work with technotrend 2300 dvb-c card? If not, are there any other software that might work with it? Quote
NeDrY Posted September 24, 2006 Posted September 24, 2006 I think it does not, because there are no BDA-Drivers available from Technotrend. The DVB-C 1500 Card works fine and is a lot cheaper ... Cheereo NeDrY Quote
CiNcH Posted September 24, 2006 Posted September 24, 2006 The TechnoTrend Premium Series (or Hauppauge NEXUS) will most likely never be supported by DVBViewer, as the BDA-API does not specify access and controlling of a Digital Signal Processor like the one built onto those DVB cards (TI AV7111). Those cards have to be individually implemented for example by using TechnoTrend's Premium SDK. Quote
