Standby when DVBViewer closes?
abaader77
I have set DVBViewer to set the system to standby when DVBViewer closes but nothing happens when I close DVBViewer (except that DVBViewer closes) ?
Do I need to do anything else to make this work? (Selecting "standby" from the Windows shutdown options dialog works fine.)
This only works if you close with the remote or with the keyboard or OSD, not if you close it the windows way.
I see. Your info + the change in my computer bios that standby mode is set S3 instead of S1 made things a little bit better (Win XP says that sys. going into standby but nothing more).
Now I have to find out which other program (not DVBViewer) that is blocking the computer to go into standby.
Thx for the help!
