JiTe Posted September 26, 2006 Posted September 26, 2006 Does anybody has a config file för Fire-dtv remote control? Quote
karrih Posted September 26, 2006 Posted September 26, 2006 Does anybody has a config file för Fire-dtv remote control? Config file for what? If you mean the FireSAT Remote Control app, it is very easy to edit DVBViewer keyboard commands to windowsmap key columnn, just open the first line and go to xml editor within app. Then you just type keys to second to last column. For exampe to get epg working you will need to put letter e on the same line as the corresponding remote key. Quote
paziii Posted October 11, 2006 Posted October 11, 2006 Config file for what? If you mean the FireSAT Remote Control app, it is very easy to edit DVBViewer keyboard commands to windowsmap key columnn, just open the first line and go to xml editor within app. Then you just type keys to second to last column. For exampe to get epg working you will need to put letter e on the same line as the corresponding remote key. Hi! I got the remote to work as you explained. However, i'm running into another frustrating problem with the FireSat remote app. When the computer comes out from hibernate, the remote app wont work, it has to be restarted and you have to press the "start remote" button in order to control DVBViewer. Besides this problem, i would have a mouse/keyboard-free environment. Solution for this anyone? Quote
