owngoal Posted September 28, 2006 Posted September 28, 2006 I see from the website that this card is supported by the DVBViewer but not by the downloadable Technisat version. How do I try out the software with this card ? Quote
Filico Posted September 28, 2006 Posted September 28, 2006 (edited) The TE version is a restricted version that only works on Technisat cards and for 15 € you get the DVBViewer Pro within lifelong update right and many other features. Otherwise, you can test your card with Transedit MMC and when it works, welcome at DVBViewer. Edited September 28, 2006 by Filico Quote
owngoal Posted September 28, 2006 Author Posted September 28, 2006 Will DBViewer Pro work with the remote control supplied with the AVerMedia card ? Quote
Filico Posted September 28, 2006 Posted September 28, 2006 (edited) What is your remote, USB or RS232? To use your remote you have two options: WinLIRC or Girder and still others. Edited September 28, 2006 by Filico Quote
