fenomeno83 Posted September 29, 2006 Posted September 29, 2006 how can i delete registration key manually? Quote
Guest Oliver Posted September 29, 2006 Posted September 29, 2006 Open regedit, search the entry and press delete. Quote
fenomeno83 Posted September 29, 2006 Author Posted September 29, 2006 I open regedit(start-execute-write "regedit") and I search username and then password but I didn't find!!! Quote
hdv Posted September 29, 2006 Posted September 29, 2006 Hello, HKEY_LOCAL_MACHINE\SOFTWARE\CM&V\DVBViewer PS: and for the next questions, a little more information please Quote
fenomeno83 Posted September 30, 2006 Author Posted September 30, 2006 ok thanks.i delete all DVBViewer folder.but i didnt'è resolve my problem:from yesterday i DVBViewer i don't see,but I hear!!!It isn't a video codec problem(I use nvidia in other player and they are OK!!!);i try other video codec but i don't see,but I hear!For this reasons I want unistall TOTALLY DVBViewer and install it!!!How can I do? Quote
Guest Oliver Posted September 30, 2006 Posted September 30, 2006 Just delete the DVBViewer folder on your harddisk. There's no need to delete registry entries since only your username is stored, nothing else. Quote
fenomeno83 Posted September 30, 2006 Author Posted September 30, 2006 I have uninstall-delete the DVBViewer folder-delete regkey,install but I have the same problem:I listen but don't see Quote
hdv Posted September 30, 2006 Posted September 30, 2006 Hello, Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
fenomeno83 Posted September 30, 2006 Author Posted September 30, 2006 (edited) Pentium4 3.2ghz,ram 1gb,video card ati radeon x600 256 mb,sat card sky stars 2,windows xp sp2 professional. DVBViewer 3.5.0.1 beta,mpeg2 codec:nvidia,h264 codec:coreavc,audio and ac3 codec:intervideo Please follow the instructions! The support-tool creates a .zip-archive, which you must post as an attachment here. Edited September 30, 2006 by Oliver Quote
