Lebeck Posted September 30, 2006 Posted September 30, 2006 (edited) Hi, Last week I installed a new XFX Geforce 7300LE graphics adapter to improve picture quality on my flatscreen... Up until I installed the new graphics adapter the only HD channel I can receive "C More HD" was running very smooth using the VGA output on my PC. All other "normal" channels are working perfectly in terms of performance. I have changed notning but the graphics adapter and the driver. The picture quality is still perfect but now it looks like frames are missing. Processor load when watching the channel appx. 35%. When using other applications like MyTheatre and MediaPortal there is no problem watching this channel. Software: Windows XP SP2 - English version - with all updates from "windowsupdate.microsoft.com" DVBViewer 3.5.0 PRO Nvidia Driver 92.91 Codec: Cyberlink Video codec from PowerDVD 7 Video Renderer: Overlay Mixer Hardware: Dell Optiplex GX280 SFF 2,8 GHz P4 512 MB RAM XFX GeForce 7300LE FireDTV-C TV Tuner - BDA Driver Version: 4.2 - Firmware: 1.2.1 Any ideas? Edited September 30, 2006 by Lebeck Quote
NeDrY Posted September 30, 2006 Posted September 30, 2006 Hi Lebeck, do you have Hardware Acceleration enabled or not? What about using VMR9? Does your Issue still appear? Cheereo NeDrY Quote
Lebeck Posted September 30, 2006 Author Posted September 30, 2006 How do I enable/disable Hardware Acceleration? Quote
hdv Posted September 30, 2006 Posted September 30, 2006 Hello, this must change in the decodersettings for the cyberlink, see under DVBViewer -> View -> Filters -> CyberLink Video SP/Decoder -> "use Hardware Accelelerator" turn off Quote
Lebeck Posted October 1, 2006 Author Posted October 1, 2006 (edited) I tried disabling "Hardware Acceleration" on the Cyberlink Video Codec... it helped - but it's still not perfect :-( Edited October 1, 2006 by Lebeck Quote
NeDrY Posted October 1, 2006 Posted October 1, 2006 I tried disabling "Hardware Acceleration" on the Cyberlink Video Codec... it helped - but it's still not perfect :-( Then kick Nvidia's butt for their d*mn f*cking Cards! Can't get my 6600GT up running with Hardware Acceleration . Without it runs fine but picture quality is a little more crisp with HA turned on ... Cheereo NeDrY Quote
