Database location and theMusic images
HappyHans
Where are the databases located?
And how do I change and image for an album. I know I can place a image in the same folder as the album and name it the "folder name". But now I cannot change that image?
Guest Lars_MQ
the databases are located in the subfolder database the location of this subfolder depends on the usermode you choose on installation.
What do you think?
As fare as i know you have two possibilities for the image:
You can put a folder.jpg in the folder and you can put a [filename].jpg in the folder, the system looks first for [filename].jpg then for folder.jpg.
