maca Posted October 30, 2002 Posted October 30, 2002 (edited) What about ... - add support for drag&drop support for audio & video files ? - add function that register DVBViewer like preferred audio & video files player ? (? un-usefull and less simply !) - Support of video plugin (like WMP or WinAmp) only audio playing - time syncronization from teletext info ?!!? - debug-Mode with a lot of impossible-to-understand LOG !!!! maca Edited June 18, 2003 by Oliver Quote
damjang Posted October 30, 2002 Posted October 30, 2002 I add: - an option to record only audio of a video channel. Quote
Guest Michael Posted October 31, 2002 Posted October 31, 2002 I add: - an option to record only audio of a video channel. you can do so by deleting the video pid from the channel... then DVBViewer only has audio to record Quote
Guest hackbart Posted October 31, 2002 Posted October 31, 2002 yes, but i'm opened for any suggestion in: "how to do it in a logical (and simple) way", without offering too much of setup parameters. I also started to think about how to offer Timeshifting quite easily. My idea is to record the data while the pause button is active. If someone has a good idea to do it on an other way i would be pleased to hear.. Quote
Guest Michael Posted November 1, 2002 Posted November 1, 2002 can't cou make something like advanced options ? wenn you click on the record button an option window appears where you have 2 checkboxes ( video + audio ) and a text box where you can enter the time after he should stop recording then you will have a form for further options Quote
