French Language File
ylber
French language osd skin (Skin en français)
Hi guys I translated the DVBViewer osd part in french
(Hello les gars,j'ai traduit la partie OSD en français)
Thank you,
ylber
Francais.zip
  • 11 months later...
Hello,
Here is corrected/updated french language file , tested on 3.5x version.
This correct translations for settings -> options -> input , that was are 50 % false ..
Etienne
Francais.zip
Guest Oliver
Thank you very much! I believe the file will be included in the next update.
BTW: I split the topic. There should be a separate thread for each language.
