MHF Posted October 4, 2006 Posted October 4, 2006 Hi! Problem: DVBViewer doesn't invoke ChannelEditor window, neither if I choose it from (rightclick)dropdown menu or click the 'Open' button in ChannelList window. ChannelList window loses the focus, so it looks like its opening something, but nothing is displayed. Any suggestions? I have the most recent version of DVBViewer. Some specs: WinTV Nova-T 500 dual tuner (terrestial) VIA K8MM motherboard Windows XP SP2 AMD64 3000+ 1 Gb memory RADEON 9600PRO GAINWARD Hollywood -something- soundcard with latest VIA Vinyl Envy drivers codecs: ffdshow (postprocessing) ac3filter Overlay method: VMR9 Quote
Tjod Posted October 4, 2006 Posted October 4, 2006 With out the nursery informations it is hard to say but i think there is something wrong in your setup.xml it should look like this: <section name="frmChannelConfig"> <entry name="Channellist">320</entry> <entry name="X">0</entry> <entry name="Y">0</entry> <entry name="W">600</entry> <entry name="H">600</entry> </section> correct it with Notepad or dealt the setup.xml but than you lose all your configurations. Where the setup.xml is placed departs on the UserMode. Quote
jf2020 Posted October 4, 2006 Posted October 4, 2006 Also something that may happen is that if you have the main window fullscreen, the channell editor window can be behind it so it's there but you don't see it. Try to double click in the video window to make it smaller and see if the channel editor is not behind it... Quote
MHF Posted October 5, 2006 Author Posted October 5, 2006 With out the nursery informations it is hard to say but i think there is something wrong in your setup.xmlit should look like this: <section name="frmChannelConfig"> <entry name="Channellist">320</entry> <entry name="X">0</entry> <entry name="Y">0</entry> <entry name="W">600</entry> <entry name="H">600</entry> </section> correct it with Notepad or dealt the setup.xml but than you lose all your configurations. Where the setup.xml is placed departs on the UserMode. Thanks! Indeed this was the case - X or Y had the value 32000 and something, so it was shown but not on the visible part of the desktop? And I had the supporttool file, but I forgot to attach it, so sorry about that. But thank you very much, especially for providing working solution. MHF Quote
