ramonchin Posted October 8, 2006 Posted October 8, 2006 (edited) What can I do with any channels like Sat 1 HD or Canal+? These channels only appear on the center of the display, with a big black frame. Is there any automatic way for filling the screen with all channels? Thanks Edited October 8, 2006 by ramonchin Quote
ramonchin Posted October 8, 2006 Author Posted October 8, 2006 What can I do with any channels like Sat 1 HD or Canal+? These channels only appear on the center of the display, with a big black frame.Is there any automatic way for filling the screen with all channels? Thanks Sorry... only vertical bars, no frame any way for automatic 4:3 to 16:9 zoom? Thanks Quote
Tjod Posted October 8, 2006 Posted October 8, 2006 any way for automatic 4:3 to 16:9 zoom?Try Options>DirectX>Video Format Detection (helps if the problem is the Bug in the new Beta 3.5.0.22).If the TV station did not broadcasting in 16:9 no. But you can build zoom configuration for that. And build a input command to change between the two configurations. Chose Zoomlevele Toggle (pull-down menu 0) Quote
