gibman Posted October 16, 2006 Posted October 16, 2006 I have placed the addrec.vbs file in the scripts folder. restarted dvbV. the contents of the file is currently this: Sub main(ID,ChannelID,Filename,aDate,StartTime,EndTime,Days,Description,Instant,isPl ugin,TimerAction,ShutDown) osd.showInfoinTVpic "Recording added: " & Filename,1000 MsgBox 123 end sub Nothings seems to happen, when I add a timer. Added timer from web, OSD, windowed mode...same. No messagebox pops up (123). If I insert the same 2 lines of code in startrec.vbs it works, when I start a manual recording right now. I get a 123 messagebox on screen and on OSD. So the script settings in dvbv are not the culprint. Msgbox is allowed. scripting is enabled. vers. beta 3.5.0.24 /Gibman Quote
Guest Lars_MQ Posted October 16, 2006 Posted October 16, 2006 Confirmed. Fix will be in the next Beta release. lars Quote
