Multiple Instances of DVBViewer
Dvb-tv
When have a setup of Multiple instances of DVBViewer. Can i suggest for the system tray icons, and window top frame bar, when viewer open. To have white numbers on them for each individual DVBViewer instance. These numbers that turn red when recording. This will make identification of any instance of DVBViewer a breeze. Whole quicker and better than without no identification, as it is now.
  • 3 weeks later...
Tried it disliked it, cannot tell which tuner is which, even which is recording. And the icons are in the system tray.
Just needing to tell quickly at a glance, which tuner is recording and which is not from the tray icon/s.
Are there any plans soon to make the tray icon show Tuner ID such as a number 1 2 3 for each tuner overlayed on the tray icon. Are the plans for the icon to change to red colour showing when DVBViewer is recording. Would these changes be implemented soon.
I think no because nearly all DVBViewer users use only one Instances.
All thou if thy have more then one tuner because it is not necessity :)
So you think other DVBViewer customers. Prefer to use DVBViewer blindly, with two tuners installed, i disagree.
