EPG Window not working anymore - how to get back
jrl
I've just started using DVBViewer and the first trials went well. Now the basic EPG window is not showing at all anymore (the window described in http://www.DVBViewer.com/en/index.php?page...r=c⊂=c6).
I've installed scheduler and NewDefault skins, can they cause this or would anyone have an idea of what could be wrong. The OSD version of EPG (the Timeline) still works.
thanks for any help!
Guest Lars_MQ
- <section name="frmEPG">
<entry name="PictureW">111</entry>
<entry name="X">1362</entry>
<entry name="Y">106</entry>
<entry name="W">600</entry>
<entry name="H">600</entry>
<entry name="Columns1">35,50,55,150,150</entry>
<entry name="Columns2">130,65,55,150,180</entry>
<entry name="Channellist">159</entry>
<entry name="Splitter1">163</entry>
</section>
Change the 1362 to 0 in the setup.xml. you semmed to have moved it outside your visible range. Don't forget to close DVBViewer first.
Thanks a lot, this worked right away! I probably had used this yesterday with 2 displays connected and moved to the other one :)
