Remote not working after video playback
olax
(DVBViewer BETA 3.5.0.50, OSD: New Default)
First of all, I know that you should attach support.zip, but as I'm at work and can't produce it until tonight, I thought I would give it a chance anyway. It COULD be a simple solution.
The problem: I use a MCE Remote with the plugin for MCE Remote. Normally it works perfectly.. but after playing any kind of video (from fullscreen mode, OSD-menus) almost all actions/keys stops working.
I CAN get the Home-menu up, but that's it. Arroy keys, OK-key etc. -nothing happens.
The fix for me right now is to go to windowed mode, the back to fullscreen mode. Then it's allright again.
/Ola
Hello,
is this happen by *.avi and *.mpg or only *.avi
The Divx Trayicon have now the focus, you can deactivate the trayicon with DivXToolbarToggleTool.exe
look on http://www.wintotal.de/Software/index.php?rb=57&id=2826
Thanks.
But in this case, it was a DVBViewer recording, *.ts. Is the above applicable then?
-And if it was the case of above, wrong focus, doesn't it seem strange that I can togglet OSD-Home-menu with the remote, don't you think?
/Ola
New info: The problem is a focus problem, as suggested. It seems like the "ActiveMovie Window" has the focus after playing any video (or audio, I think).
Anyone know a workaround for this?
Extra question: I have problems getting automount ISO to function correctly. What options should I have/not have in the daemon tool (automount/autostart/autolock etc)? -And should I put daemon.exe in autostart?
/Ola
I had the same problem with winlirc plugin. I installed Girder and The girder control plugin. No focus problems anymore.
Edited by Kuidas
