HDTV only in preview window of TransEdit
nikocity
How can I make DVBViewer Pro showing HDTV channels?
If I scan in TransEdit for AnixeHD (Astra 19.2) I get 4 channels including SAT1 HD and Pro7 HD. If I click on preview I can see and hear the video. I send it to DVBViewer and choose the channel, but DVBViewer is not willing to give me any video or audio output on HDTV channels. What is the reason?
For Transedit preview settings all codecs are set to Cyberlink (PDVD7). In DVBViewer I use the following in DirectX section:
Video Render: Overlay Mixer
Audio Renderer: Cyberlink Audio Renderer (PDVD6)
MPEG2 VideoDecoder: Cyberlink Video/SP Decoder (PDVD7)
H.264 Video Decoder: Cyberlink H.264/AVC Decoder (PDVD7)
MPEG Audiodecoder: Cyberlink Audio Decoder (PDVD7)
MPED AC3 Decoder: Cyberlink Audio Decoder (PDVD7)
Postprocessor: none
Audio Format detection: checked
Video Format detection: checked
Use DVBsource for MPEG files: checked
I'm using a Pinnacle PCTV Sat HDTV Pro USB 2.0 on an ASUS Nforce4-Board with an AMD Athlon 3800+ Processor, ATI X800XL graphic and 1GByte Ram.
Any ideas?
Patrick
Get the latest beta from the member's area. There was a change in the format for dvb-s2. With this update the settings from transedit should work..
Great, that works.
Patrick
