Interactive channel recordings
Dvb-tv
Is it possible to schedule these channels, when there is nothing listed in the EPG. I know i could manualy start a recording, go to the pvr then stop it. Then alter start stop timers, there must be an easier way to do the same from the EPG, but how.
I will try it, EpgUpd an EPG Updater envoker i think.
If it's just envoking an EPG Update, may not be much use. The EPG for interactive channels never have any EPG data for them yet. This is the same how many days DVBViewer is active. Will try the script and let you know.
