Derrick Posted November 4, 2006 Posted November 4, 2006 28E, 11797H DVB-S2 scrambling temp. switched off ! Quote
ice coffee Posted November 5, 2006 Posted November 5, 2006 28E, 11797H DVB-S2 scrambling temp. switched off ! Sorry to be Off topic but do you find that changing between HD chans on sky crashes DVBViewer, it is fine with all other euro HD chans just sky HD causes it to crash ??? Quote
Derrick Posted November 5, 2006 Author Posted November 5, 2006 How can I switch between SKY_HD_channels when only one is open? ..and if I had such problems, I would mention it Quote
Rittberg Posted November 5, 2006 Posted November 5, 2006 Sorry to be Off topic but do you find that changing between HD chans on sky crashes DVBViewer, it is fine with all other euro HD chans just sky HD causes it to crash ??? Are you running DVBViewer with PDVD 7 h.264 decoder video acceleration - enabled ? If yes' try to disable it and see what happens. Quote
ice coffee Posted November 5, 2006 Posted November 5, 2006 Are you running DVBViewer with PDVD 7 h.264 decoder video acceleration - enabled ?If yes' try to disable it and see what happens. I am running core AVC but I will try Pdvd Quote
