lua.dll?
olax
Hello,
Sometimes (=I haven't seen any clear pattern of it yet) DVBViewer complains about not finding LUA.DLL at startup, but when I confirm the error message, DVBViewer starts and works anyway.
I did a search on the harddrive for the file, but could not find it.
Can anyone tell me what it is, if it's needed, and the reason why the error message only show up sometimes?
/Ola
Guest Lars_MQ
lua.dll is part of girder, not used in anyway directly by the DVBViewer. Indirectly maybe by the girderplugin via girder. I think you should examine your girder installation. :)
Now I have uninstalled the Girder trial version, but at startup DVBViewer still complains about missing file lua.dll. :(
The DVBViewer girder plugin is a plugin for Girder, right? -And DVBViewer doesn't start Girder, right? Strange.
Hmm... The error message says "DVBViewer.exe" in the title, as if DVBViewer is the program that needs the DLL.
/Ola
Edited by olax
