Changing Filter Properties
Klaus_1250
I've installed the latest DVBViewer Pro (beta) and DVBSource filter, but I cannot find the following option:
By selecting View -> Filters -> DVBSource in DVBViewer you may open the DVBViewer Filter's property page, that allows to adjust some of its settings.
The View-menu doesn't show "Filters" (neither did the latest stable release). How can I activate it?
you must be looking at the wrong place..
Thanx. Indeed, I was using the right-click menu (top menu is turned off), which is almost the same except for the Filter-entry. Perhaps this can be moved to a Feature Request: "Show Filters in right click menu"
I agree...
:bye:
