burgerman Posted November 9, 2006 Posted November 9, 2006 Program freezes at start up showing only white background. Exiting program doesn’t help neither closing the program in Windows program manager. Only rebooting stops the program. Got a feeling that this might have something to do with explorer.exe... well, just a guess... This doesn’t occure all the time, but it’s very common when for example Explorer or Opera is open. Very common feature is that there is only sound with no picture at all. These can be quite annoying features from time to time. This problem didn’t occure in the very first beta versions, only with the couple of the latest and with the final pro version. support.zip Quote
Derrick Posted November 9, 2006 Posted November 9, 2006 ..if you use plugins, have a try without. Quote
burgerman Posted November 9, 2006 Author Posted November 9, 2006 ..if you use plugins, have a try without. I disabled input plugins, that is winlirc... but for beginners sake, could you be a bit more spesific if there is something else I could do? Program starts much faster now without any hang-ups but of course remote doesn't work without enabeling it again. Quote
Derrick Posted November 9, 2006 Posted November 9, 2006 but for beginners sake, could you be a bit more spesific if there is something else I could do? I have no idea. I don't use winlirc but others do withou any problems.. Quote
