IP Address
johnchapman903
If anyone could help, I have just installed a Technotrend Hauppauge Satellite Card. It seems to be installed properly, however i can't get any channels on DVBViewer. I think this could be caused by not having an I P address , how do i obtain this. Any advice would be much appreciated.
Cheers John. :(
Hi right the system is a p4 3.6 ghz with a radeon x800 gto graphics card tecno trend bda/dvb-s capture tunner card using broadcom driver to run it . Tcp/ip is not enabled is the error message that i get when i try to repair the connection can you please advise on how to locate the setup.ini/setup.xml and the DVBViewer oh and its the latest DVBViewer version v3.5.0.1(beta) i think that covers everything
Hello,
please use the supporttool there you can find in the link and execute it in the DVBViewer installation folder.
The Tool make a support.zip which you post here.
Silly quetion where is the installation folder i've opened program files then DVBViewer but no install folder
Hello,
i think you have the installed DVBViewer Pro with the setup.exe there you have loaded from the Member-Area.
And now you put the supporttool in this folder like C:\Programme\DVBViewer Pro 3.5\DVBViewer.exe.
MPEG2 Video Decoders:
Nero Video Decoder: 00810000
NVIDIA Video Decoder: 00800001
InterVideo Video Decoder: 00700000
CyberLink Video/SP Decoder (PDVD7): 00602000
DVD Express Video Decoder: 00600000
Nero DVD Decoder: 00600000
ATI MPEG Video Decoder: 005FFFFF
Nero Video Decoder HD: 00400000
InterVideo Video Decoder for TechnoTrend: 00400000
MPEG Audio Decoders:
AC3Filter: 40000000
ffdshow Audio Decoder: 3FFFFFFF
MPEG Audio Decoder: 03680001
Nero Digital Audio Decoder: 00810010
NVIDIA Audio Decoder: 00800001
InterVideo Audio Decoder: 00700000
CyberLink Audio Decoder (PDVD7): 00602000
DVD Express Audio Decoder: 00600000
InterVideo Audio Decoder for TechnoTrend: 00400000
System:
DVBViewer Version: 3.5.0.1 (beta)
DVBSource Path: C:\Program Files\DVBViewer\Filters\PushSource.ax
DVBSource Version: 2.8.0.0
OS: Windows XP (Service Pack 2)
DirectX: 9.0c
Memory: 2047 MB
CPU: Intel® Pentium® 4 CPU 3.60GHz
CPUSpeed: 3617 Mhz
Is that ok
No that is not o.k.
Start the support.com/exe in the DVBViewer Folder and attache the created support.zip here in a post.
No personal information ist created, just the DVBViewer related settings etc.
Still confused opened C programs then DVBViewer entered this but no file named DVBViewer.exe. Please could you explain in detail. Then how do i attache it.
Thanks John
Edited by johnchapman903
