SS2 4.4.1 BETA BDA released.
gibman
HI,
Technisat have published yesterday 4.4.1 BETA
Software 4.4.1 Beta Version (13.11.2006)
TechniSat DVB: Windows 2000 (ab SP 4) / Windows XP SP2 / Windows XP x64 / Windows Server 2003 / Windows Vista RC2 (x86)
TechniSat BDA driver: Windows XP SP2 / Windows XP x64 / Windows Vista RC2 (x86)
This beta release does not contain any user documentation.
Download: Software 4.4.1 Beta Version
Please create a full system backup before installing this software package.
The use of this beta software packages is at own risk.
DOWNLOAD here:
http://www.scaistar.com/pafiledb/index.php...view&id=452
Indeed it is a BETA - I had no luck with this.
The new BDA device did show itself in the device manager.
Also dvbV lists the new device under hardware.
Nothing is tuned though when I tune into a dvb-s channel.
dvbserver also lists the device.
when using dvbv with unicast nothing is tuned.
although dvbserver says one client connected.
The log window shows me tuning data being listed in a never ending loop.
/Gibman
Solange es dazu nicht mal ein Changelog gibt, würde ich da sehr zur Vorsicht raten: Abwarten!
Sorry:
As long as there is not a Changelog to this, I would recommend the caution very much there: Wait!
I`ve installed the Beta Drivers. But i Don`t use the BDA. It works fine here..
Greetingz,
Ghost-Storm
