Win Tv Supported?
soothsayer
My Win Tv HVR-900 has no burned out and i'm looking to buy another WinTV product and i see the WinTv Nova T PCI is a supported hardware and i wondered if the new WinTV Nova-T 500 is supported by DVBViewer?
I wouldn't like to burn out the card because of trying to record 2 streams at once, (which i think i did with my old one hence the not working anymore)
If anyone is using it now please tell me if it a worth while investment for recording DVB-t.
Thank you
Thank you
As long if the the T-500 has stable WDM drivers or better BDA drivers, then this shouls work under DVBViewer.
Have no idea on the quality of the T-500 so best wait for some more answers.
Thanx for the info, but could you explain what do WDM and BDA stand for and is BDA a better option for DVBViewer?
Windows Driver Model = old type of Windows multimedia hw driver originally designed for Win98 & Win2K (only old or badsupported hw use WDM nowadays!)
Broadcast Driver Architecture = new type of Windows multimedia hw driver introduced with DirectX 9
DVBViewer was originally created for the Technisat SkyStar2 PCI card only, and from V3.2.3 is supporting other hw provided with (well designed) BDA driver...
Till now there are no others chance for use DVBViewer, nor available, nor projected...
:bye:
Thanx all
Well it look like i'll get it anyway and see the results. thanx all for your input
M
It seems that the WinTV Nova-T 500 has a BDA driver (witch however can't assure that it's fully working with DVBViewer): find it at bottom of this page of the Hauppage UK forum
Good luke!
Oh well it doesn't work well, it doesn't want to initialise the device properly. It was great using this software and hate to stop using it. Maybe in a few years when i get satalite.
Bye then
thanx
WDM Drivers are NOT supported, only BDA.
Well, If I install the WDM drivers then DVBViewer works but as explained in the twinhan 1030A thread very unstable video. BDA works a bit better on FTA channels but encrypted fail completely as explained in the same thread.
