HTPC mode
ramonchin
Hi
How can I exit from HTPC mode to window mode?
Thanks
Hello,
go to OSD, htpcHome -> thesettings -> Unlock HTPC-Mode.
Now you have the window mode and you can go to options,
and take the htpc-mode off (Options -> General -> "HTPC Mode:")
:jump:
Hello,
:jump:
But, what key does set the setting screen? I push "esc" and nothing happens... I can´t exit from full screen video.
Thanks.
Thanks.
Pressing Esc should bring up a menu. If not, maybe DVBViewer is not running in foreground. Press Alt-Tab to bring it to foreground.
In the esc-Menu should be one entry "Home Theatre PC" select this, then go to "Settings" and "Unlock HTPC Mode"
If you cant find "Home Theatre PC" entry in Menu, then press "O" to go to Options and configure the OSD-Menu properly
If you found the setting and did all, then just double click on the TV screen to go to windowed mode. Double clicking toggles fullscreen mode.
Edited by esackbauer
Ok, solved.
Thanks
