B2C2
Caramba
Das Problem ist, dass ich aufgrund lizenzrechtlicher Gründe den B2C2 Filter nicht mit dem DVBViewer ausliefern darf. Leider haben die Technisat Leute vor dem Pressen vergessen eine Information diesbezüglich auf die CD zu packen.. Die Lösung gestaltet sich recht einfach: Die Datensoftware muß unbedingt zusätzlich installiert werden
So where did i can download this ---------------ing programm???
Guest Michael
you've got it on cd.... it's implemented in the technisat software.....
did i have to install it from CD or did he makes it on his own?
I have checked something: when i reinstlall DVBViewer it works fine untill i restart my PC then i become this error....
So where did i can download this fucking programm???
Ask techniSat. Maybe that is a driver problem of his b2c2 driver.Maybe you get here an answer of your question.
Works your TV4PC? Only if this programm works fine, the DVBViewer can work also fine.
Here is the board of the DVBViewer and not the Board of the SS2 from TEchniSAT. Here you get also some informations. And here you can download the drivers from the TechniSat Homepage.
P.S. Make love not ... :rolleyes:
sorry i have called Technisat and he told me i should ask on thios website!
TV4PC works fine? It doesnt Work on my PC! Something with wrong file format!
but Thx for your answer!
have you installed an mpg2-driver? And have you installed the original driver 4.22 from TechniSat? If you have this not on CD, download it from TechniSat Homepage.
If this not work, the DVBViewer can also not work. Look at setup4pc for more informations. How strong is your signal?
This is a brashness! :rolleyes: They make a lot of money with theire card and give not support.
But we are a helpful community and if we can help we do it!
Diese blöde 0190 Nummer kostet dazu noch 0,62 €!!
Habe jetzt den Mpeg2 Codec installiert und jetzt sagt er mir Kanal nicht gefunden...aber nachdem ich DVBViewer erneut installiert habe funzt der auch wieder!
ich wollte mir den Trweiber runterladen...aber 10 MB sind mit ---------------ing ISDN irgendwie nicht so schön zu laden...mal sehn...wenn ich wieder inner Schule bin werd ich mir den rnterladen!
Danke für eure Kostenlose Hilfe :rolleyes:
ganz kostenlos ist sie nicht. Denn eigentlich erwartet die Community, dass Du Deine Hilfe später auch anderen zur Verfügung stellst. :rolleyes:
na logisch!
Ich glaube ich werde mir diese DVB Version Kaufen der Author(namen verlegt) hat mir geschrieben das der viel mehr features hat..kann mir einer sagen ob der irklich besser ist als die Version zu der Skystar2?
MF-g
Ganz definitiv! Eine meiner Lieblingsfunktionen ist zum Beispiel timeshift. Jeder kennt den effekt wenn man an der spannensten Stelle im Film auf Toilette muss. Damit ist das kein Problem! Du aktivierst es einfach, klickst auf Pause und wenn Du wieder kommst schaust Du genau an der Stelle weiter wo Du gegangen bist und das live im Fernsehprogramm. Schon allein dies Funktion ist die 15Euro wert. ABer es kommen noch viele andere nützliche Funktionen hinzu ...
genau das ist das geile feauture was ich schon immer ahebn wollte! Funktioniert das echt guit?
Stimmt schon, Timeshift is ne feine Sache... :o)
Guest Michael
jupp funzt supa... ist am anfang etwas gewöhnungsbedürftig wegen der bedienung..... aber danach ist es ne feine sache..
So ich habe das Geld ebend überwiesen! Hofentlich bekomme ich bald die bestätigungs mail!
