Shaked video with VMR9
ramonchin
Hi!
I'm using the las beta in HTPC mode + VMR9 (VMR7 doesn't work with OSD in this version :jump: )
All the channels except H264, shake intermittenting. H264 is DXVA accelerated (cyberlink) like mpeg channels (purevideo)... could it be a problem with deinterlacing? ... I don't know.
Video and audio format detection ticked.
OSD VMR fix ticked too.
I'm using last beta.
My vga is a Nvidia 7950GT
Thanks.
Edited by ramonchin
Hi
I am using cyberlink 7 decoders, but in my case activating "use first cpu only" solved the jittering issues.
Maybe it helps...
EDIT: sorry, I re-checked. What solved my problem was DE-activating "OSD VMR HT FIX". I have an ATI 300SE.
regards
steph99
Edited by steph99
