Foxmul Posted November 22, 2006 Posted November 22, 2006 Hi Via EPG, I'll record 2 events: the beginning time of second one is before the ending time of first one, on the same channel, same day, every week. Do you think I'll have some kind of problems with this kind of recording set? (I can't change the timing manually...) regards Quote
Tjod Posted November 22, 2006 Posted November 22, 2006 That is no problem. It is all though possible to record more than one channel at the moment if thy are on the same transponder (frequency) Quote
bergh Posted November 22, 2006 Posted November 22, 2006 Hello ! If it is the same channel overlapping it is not a problem. If it is on the same Transponder overlapping , double recoding on the same and on different channels (On the same Transponder) The Sky is the limit Or the speed of your memory / Harddisks. I think even 10 (TEN !!!!) parallel Recordings could be worked on by modern hardware. 4-6 I have already done. some Overlapping and some different channels at the same time. So at a given point of time 6(SIX !!!!!11111) Streams were written on the HARDdisk in parallel. No Problem ! Quote
