info about a bug fix
porksfree
A couple of months ago, i posted two bugs, info about the possible fix?
thanks for your work
rendering bug with custom graph in DVBViewer root directory
So, probably there is a bug in rendering Video if j put a DVD.grf in DVBViewer root folder using VMR insted of overlay.
This is my test:
- DVBViewer using default graph (without DVD.grf in the root folder)-> OK in Overlay and VMR9 mode (in VMR there is a little bug that j posted in the apposite section)
- DVBViewer using custom graph, DVD.grf -> OK in overlay, in VMR9 only audio, no video!!!
If someone confirms, we can post it as bug in bug report section.
bug in DVD Navigation
There is a bug in DVD Navigation: Preview and Next Chapter have the same action! They both work like the "NEXT" command.
Edited by porksfree
