Recording from the same mux
arc03
Hi.
If I record FTA channels from the same mux it works ok, but if I try to record encrypted channel and watch another from the same mux it doesn't work, says "hardware not available". So is there some kind of limitation with encrypted channels? Same problem (if any) with the official DVB & beta.
With most (older) cards don't work any 'Multi PID Descrambling' , only at FTA.
So it's tvcard problem.
Ok, thanks.
