dioveht Posted November 24, 2006 Posted November 24, 2006 There is a little bug on my system when I enter in the CAM menu. I have a Technotrend TT-S3200 with CI and T-Rex 4.1 CAM and it works great, but there is something wrong in CAM menu. There should be 5 options but only 4 are present in DVBViewer and all options are shifted by 1 position. Just an example... Menu should be like this: 1. Option A 2. Option B 3. Option C 4. Option D 5. Option E DVBViewer Menu: 1. Option B 2. Option C 3. Option D 4. Option E If I select "1. Option B" DVBViewer executes "Option A".... if I select "2. Option C" then "Option B"... and so on... Same problem in "Show CAM" and OSD CAM Menu. CAM Menu is OK in Technotrend MediaCenter software and all options works fine. My System: Intel Pentium4 D 920 Asus P5PL2 1 Gb RAM ATi Radeon x1600Pro SB Audigy Platinum Technotrend TT-S3200 with CI Windows Vista RC2 Built 5744 / Windows XP Pro SP2 tested on DVBViewer ver 3.5.0 / 3.5.0.50 / 3.5.0.101 Quote
Thomynator Posted November 24, 2006 Posted November 24, 2006 Same Problem here ... Also use the same DVB card. But different Cam's all have the same problem. I had to manually reinstall the API ttAPI.dll because the old one stopped working i don't know why. The one i have had in the directory was also 1.0.0.5 but just 65kb big. The working one i found somewhere on this forum here is 1.0.0.5 but about 150kb. Quote
w8andc Posted December 3, 2006 Posted December 3, 2006 (edited) My Technotrend S2-3200 DVB-S2 card and DVBViewer 3.5.0.101 works good in combination with an IRDETO CAM for viewing Euro1080 HD1 and decrypting is OK. After installing the update 3.5.0.120 the decrypting is not fluent anymore. Many discontinuities and video stops all over the time. The update 3.5.0.121 doesn't change anything! I was urged to go back to 3.5.0.101. Does someone have the same issue? By the way: I was testing DiSEQC 1.2 in combination with Technotrend S2-3200 and DVBViewer 3.5.0.120 and this works very good. ************************Update:24/12/2006************************************* Positive news! It seems that using the AlphacryptCam with the latest software 3.09 works quick and very good in DVBViewer 3.5.0.121. So for some reason the IRDETO cam is screwed up in the latest DVBViewer version and not in the version before. ******************************************************************************** *** Edited December 24, 2006 by w8andc Quote
bc2006 Posted December 20, 2006 Posted December 20, 2006 Always the same problem with 3.5.0.121 and the powercam module. The first line in the (all) cam menus is not present. Regards, Quote
