Bug or feature - DVBServer
wheelie
I am using the NetStream Plugin (latest version) in unicast mode. Seems to be working fine. My problem is with DVBServer.
In order to use netstream I have DVBServer running. I then start DVBViewer. If I try to close DVBViewer it's DVBServer that closes and not DVBViewer.
Is there any way to change this so that I can close DVBViewer and keep DVBServer running so that others using the unicast aren't interrupted.
This has occurred with all versions of DVBViewer
Thanks
Guest Lars_MQ
You use the taskscheduler for DVBViewer? If yes try disabling it in the DVBViewer Options.
That worked. Many thanks
cheers
