Signal strength/quality meter? (Pro)
Pekkiz
Hello!
I have a problem with the newest pro beta version... How do I enable the signal strenght meter? I haven't seen any good explanation on this problem so I thought that I should ask..
Thanks in advance!
Go the bottom of the DVBViewer Windows and click between the channelname and the Mono / Stereo / AC3 logo a few times.
BTW: For my Twinhan DVB-C, it can only show "Signal Stength", but not "Signal Quality"? (not that it is usefull on the Twinhan, Signal Quality output seems to be broken, but perhaps Twinhan will fix it in the future).
Edited by Klaus_1250
  • 3 years later...
  • 1 year later...
Signal Strength NOT Signal Quality is still being shown in DVBViewer 4.5.0.0. with DVBWorld 2104C USB tuner. This is a pain when adjusting for best reception. It keeps me using MyTheatre since it does show signal quality (and signal strength) no problem.
