New Beta update
hackbart
we finished the new update which comes with the following features and fixes:
Version BETA 3.5.0.120
[*]Fix: DiSEqC 1.1 and 1.2 values where not saved.
[*]Fix: COM: Adding EPG via COM did not work.
[*]Fix: CAM: Fixed serveral issues with CAM support for Twinhan (thanks @maju), general small reworks on CAM-Support.
[*]Fix: DVD-Audio did not use the selected soundcard.
[*]Fix: Language: Fixed several translation problems and reworked the english text of the wizard (thanks @SF100).
[*]Change: VCR: MPEG with several audio tracks can be recorded.
You can activate it in options -> recording -> recording similar to the TS options.
Attention: Only the audio-streams present in the channellist are recorded. No automatic detection as in TS-Recordings.
PLEASE CHECK YOUR SETTINGS! PVA and M2P formats have been removed.
[*]Change: Recorder Window: Since the TSD (Transponderdump), NFW (NoFileWrite) and the recording folders tags are mostly unknown and not easy to understand, I changed the presentation a little bit. You can now adjust the settings in the recorder window. The user will normally not see the extensions of the description, cause it's now assembled on saving and disassembled on loading.
The Recfolder is activated if you have more than one recording folder defined.
[*]Change: Data tags: The #EPG.* tags are now also available in the OSD-EPG, OSD-What's Now and OSD-Search window.
[*]Change: Wizard: The language can now be selected on the first page. It will be wizard language and the preferred language in the DVBViewer.
[*]Add: EPG-Window: STRG-H toogles the visibility of the channel list on the EPG tab (also via the popup menu).
[*]Add: Recorder Window: STRG-H toggles the visibility of the channel list (also via the popup menu).
[*]Add: Recorder Window: added popup menu to the timer list and added short cuts for most buttons and menus.
[*]Add: Recording Options: added writing of additionally info data for NTFS Filesystems.
[*]Fix: EPG Window: position not saved.
[*]Change: Recorderwindow: Cleaned up tab order. ESC closes the window.
[*]Change: Channel list: Changed pictures for channel list.
[*]Fix: Scanner: Grigas scanner fix for nile sat.
[*]Fix: COM: Fix WindowID not send via COM on dialogs.
[*]Fix: EPG-Window: Fix timeline double click didn't work anymore.
[*]Add: Hardware: added support for KNC1 BDA DVB-S und DVB-S2 devices incl. DiseqC 1.0 (requires the latest bda driver).
Christian
Guest Lars_MQ
A little helper is in the beta. Simply start the wizard.bat to get the DVBViewer wizard. :)
Please post follow ups in the Beta forum: english or deutsch.
Guest Lars_MQ
A hotfix for the beta is in the members area.
If you've downloaded the Beta 3.5.0.120 please download the new beta.
It fixes an error in saving the timers. All Timerdescriptions were added up on every programm exit.
