Recording problem when running some days
ReflexNPG
Hi!
I have an annoying problem with DVBViewer pro 3.5.0, on a cinergy dvb-c card (windows xp sp2).
If DVBViewer runs longer then appr. 3 days, something goes wrong inside the program. First days everything runs fine, but then the recorded .mpg files are only 4 bytes long - the .txt file is present and contains the right information. The program shows a black window.
Please give me a hint, how to avoid that or in case thats a bug, when it will be eliminated.
Thanks!
Reflex
