Genlock/overlay functionality to mask out static logos
AndersB
Some static channel logos are really burning my plasma screen so I would like some kind of genlock/overlay functionality in DVBViewer so that I can bind an overlay image to each channel to mask out the logo from the output signal. That way, instead of a vibrant channel icon that burns my screen within an hour of watching I can mask it out to only show a complete black channel icon which would not render any burn-in.
Guest Lars_MQ
You could use the myclock.xml skinpage. simply put a black image of the right size in the right place into it and let it display in the OSD ;)
There will be for sure no genlock functionality implemented. :)
But can I use different skinpages for different channels? So far, I have not come across two channels with the same logo...
