Method GetPageAsRaw not in documentation
Romme
Hi
I have seen the method GetPageAsRaw, but it's not in the documentation.
Is it possibel to use this method and if how ? ;)
/Romme
Guest Lars_MQ
Yes you can use this method. It delivers a one dimensional byte safe array with the raw ttx pagedata (with all command sequence etc.).
It's useful, if you don't want the html stuff pollute the ttx page data. ;)
Do you have an example of how to use it?
I have tryed using it from a .vbs fil like this:
Set myDVBViewer = getObject(,"DVBViewerServer.DVBViewer")
wscript.echo myDVBViewer.Videotext.GetPage(100,0)
wscript.echo myDVBViewer.Videotext.GetPageAsRaw(100,0,0)
The GetPage works fine, but I only get a "1000" from GetPageAsRaw.
/Romme
Thats because you do not use it correctly ;)
1000 is the size of the page as result. The whole command looks like:
function GetPageAsRaw(Page: Integer; Sub: Integer; out List: OleVariant): Integer;
Christian
I see.. do you have a VB sample?
Christian
  • 5 weeks later...
Thanx, I got it now :(
Anyone know how to convert it to HTML or an image?
/Romme
Thats because you do not use it correctly :jump:
Christian
