Pinnacle PCTV USB Stick and Skystar II
linusalba
Hi, I'd like to buy a cheap DVB-T receiver. I've found Pinnacle PCTV USB Stick in a shop in my town.
Does it work with DVBViewer? Is it possible to use both DVB-T receiver and Skystar II sat receiver with DVBViewer? How could I set DVBViewer to use both?
Thanks, Marco :bye:
If there is a BDA driver, most likely yes.
Yes.
After having installed the driver, Options -> Hardware -> Scan Devices. Then scan for DVB-T channels.
I have a Pinnalce PCTV Usb Stick with a Skystar 2 and so far there has been no problem at all.
Thank you for your info! I like DVBViewer since 2001 :( !! :)
